2012 Cruze LT with automatic transmission, 1.4 L Turbo engine. Was parked in the driveway 2 days ago, and this morning when trying to start it, there was no click or anything and the starter would not turn the engine over. All the lights come on on the dash and the radio comes on. I disconnected the battery (2 years old) and cleaned the terminals. Performed a load test on it and it tested good. Recharged it and hooked it back up. Ran a wire from the S terminal on the starter solenoid and touched it to the positive terminal on the battery and the starter cranks the engine properly. Replaced the exhaust camshaft position sensor as I read somewhere in my research that sometimes causes a problem. Tried starting it in neutral and park after jiggling the shift leaver around. Still no start. Appears the computer is not allowing it to start because of some problem somewhere. No error codes are stored in the system. My guess is some sensor is sending bad info to the computer and the computer doesn't allow it to start. Swapped the relays around to see if I had a bad relay and checked all the fuses. Still no start. Any help would be appreciated as we live out in the country and can't even get it started to take it to a dealer.
