Hello:
Not sure if this actually got posted the first time, so I'm reposting it as I didn't see it under the heading "NEW". Sorry if its a duplicate, can the mods please delete it if it is. Thank you.
Wondering if you ever found the source of your gas smell. I have the exact same model/year with 312,000K.
I only smell gas in the cabin when stopped at a stop light, once I start driving there's no longer any smell. I drive 45 minutes to the city and there's NO scent of any gas, only when stopped as mentioned does it become noticeable.
I've read all the different posts here regarding this problem and it seems like its not an easy task to find the source.
I opened the hood while I had the engine running and using a bright flashlight I saw no sign of gas or any noticeable smell. Very strange on what's causing it.
Lastly a few months back I also replaced the purge valve, as I had issues starting the car after refueling.
I've also read a cracked vapor cannister could be a source, if I got that right. Where is this located?
Thanks for any insight.
Cheers
Shark1959
Hello GMman:
I did have the dealer replace the spark plugs not long ago when I had brought the car in for a code P0302 and a P0420. A few days later the P0420 returned and they replaced both cats and oxygen sensors. If there was a loose spark plug would you not notice a strong smell of gas with the hood open and the engine running? I even pulled the cover that's covering the coil pack and got my nose very close and there was no scent. I'm going to check this later as a possible cause, so I can rule it out once the car cools down. I did find one other post on this forum where a poster did find a loose plug though that was causing this problem.
Cheers
Shark1959
