Stock Turbo Flow Rate
11K views 10 replies 4 participants last post by  gdenton2000
#1 ·
Does anyone on here have technical data on the stock turbocharger? Looking to see what max flow rate is? Thank You
#5 ·
Typical spec for a turbo is horsepower, which I suppose could be back calculated for a rough airflow number.
I believe that max Horsepower of the 1.4L turbo is unknown to most of us, the computer will bleed off the charge air beyond 16 lb of boost.
I would be more interested to find out much boost the stock turbo would safely make across the RPM band without the ECU messing with airflow.
For example my ECO has a peak torque at 1850 RPM compared to other models of 2500 RPM, Horsepower is limited to 138 @ 4900 RPM for all models with the 1.4L.
Going beyond 138 HP which requires a tune and some modifications, however it seems that people tend to upgrade the turbo to get past the 180 HP wall. (might be lower)
#7 ·
Boost is resistance, so you could have the same amount of airflow at two different boost levels depending on modifications. So that is the reason I look for airflow. And also just curious to compare what max airflow of the turbo is compared to what airflow I am running. To see how much boost is really left in the turbo. And just was wondering, if someone did the research to find out the technical data for the stock turbos. To know max boost pressure, max airflow, max power. Thank you.
#8 ·
So Vermont Tuning is claiming that the Stock Turbocharger will only flow a maximum of 18.5lb/min.
Which I know the turbocharger can do more than that.
They might be claiming that one: to get people sold on their upgraded turbocharger and two: the turbocharger is way out of it's efficient zone at that airflow.
So the turbocharger should be easy able to hit 20lb/min.
So if anybody has personally seen more than 20lb/min on stock turbocharger. I would appreciate if you post letting me know.
Thank you
And ssnscruzeeco2015 the stock turbocharger is capable of pushing past 16psi of boost pressure, my personal car is pushing 20psi of boost from 3800-6500rpms. Which at 3800rpms its 16lb/min(20psi) and at 6500rpms it 19.5lb/min(20psi).
#9 ·
Any data on bottom end boost capacity, between 1200 and 3800, that is where my car spends 99 per cent of its time at? In particular if I can stay in 6th and just increase boost to overcome a few more hills. I have nearly 40000 km of stock data collected. The ECO is already as efficient as GM can tolerate, now my goal is to see how much farther I can take bottom end boost and my FE.
#10 ·
I am honestly not if that is a question or just a statement. Honestly not understanding what your saying. But if you are looking to get as much boost as boost below 3800? Then you will need to do some cam tuning to reduce overlap as much as possible to spool the turbo as fast as you can in low end. You could also advance both cams in low rpm to gain more low end power.
