Winter Tire size for 2018 Cruze Redline?
4.9K views 13 replies 7 participants last post by  thebac
#1 ·
Sorry for the stupid question:
I don't want 18 inch rims for my winters, 16 is ok. would 205/55/R16 fit my cruze even if i used the OEM 18 inch rims from the redline?
Thanks
#2 ·
Well you can't put a tire for a 16" wheel on an 18" wheel, so you'll need a set of 16" wheels.
Reactions: TheDude
#3 ·
For my winter setup my car came with 16's (LT trim) I went down to factory 15's (LS Trim)
I ordered the steelies right from the dealer, got some decent snow tires and off I went.,
I see no reason why you could not use 15's as well.
Huge savings in money and my car runs like a champ in these cold, snowy canadian winters...
Jason
#5 ·
Yes, absolutely. Or, as above, even a 15" wheel/tire set would work. Probably even be a little cheaper.
#9 ·
The 205/55R16 is only about 0.8% off from a 225/40R18, so it's pretty close (I'm real picky and like either 0.0% off, or a separate tune to correct - I'm lucky with my Volt in that 205/65R15s I run in winter match the stock 215/50R17 diameter that I run in spring/summer/fall). But for both 15 and 16" wheel/tire sizes, neither has anything that is an exact match to the 18" tire size. 15" tire sizes seem to be a bit closer at 0.4% off (plus or minus depending on the size).
#14 ·
Just buy a set of 16" cruze wheels and 205/55/16 tires. Thats what I put on my daughter's 2016 Premier that had 18" summer tires. Worked perfect. Look on FB Marketplace or car-part.com for the wheels.
