81 - 100 of 141 Posts
Got a link that warranty tracker? I created a my.chevrolet.com account, and I see this one "Special Coverage N172097060". A google search does not show any results where all the other ones do. It shows the expiration mileage as 80,049 (odd numbers?). Is that the one?
Side object sensor modules (blind zone, side detection...Etc) DO require programming when replaced. They are NOT plug-n-play.
Special coverage adjustment #N172097060 was released April 1st.
It covers blind zone alert system failure due to water intrusion for 6yr80kmiles from original I'm service date. It covers 13-16 Gen1 Cruzes, 14-15 Impalas, and 13-17 Acadias..
You get new modules, plastic shields to protect the module and connector, and a new harness.
Would the programming be something any shop with a 2 way scan tool could do or is it dealer only?
you are correct, sir.
Now will see:
1) if GM will reimburse me for the $1k I spent two years ago to repair this
2) if they will honor that this latest occurrence happened before 80K miles. My car just went over 80K, but I called the dealership before this occurred. And at that time they stated to text them photos to demonstrate the failure before 80K miles
Appointment set for 4/19 (if parts can be acquired).
Now will see:
If it was me, I'd hold off on #1 until you're sure you have #2 in the bag.
I had mine replaced today under this new coverage. It required multiple days as they didn't have the part in stock the first day.
Externally it looks much different from before. I didn't attempt to remove it or anything, however. Here is a photo I took, showing the new design.
(I cant post links yet, so you would have to manually enter this.)
http: //imgur.com /reQlOSK
Interesting. My local dealer had ordered in some parts. One module has arrived, the other is still on backorder. He hasn't specified whether it's a replacement of the original or this new design you seem to have received. I guess I'll find out in the next week or 2.
Welcome Aboard:welcome:
BDC,
It's not a scan tool setup procedure. It's an actual programming event requiring access to the GM SPS
Does the tech need to know which serial# is on which side? I received my kit an will install it tomorrow. Going to take it in and want to make sure they are not going to have to tear it apart. I can just photo the numbers if I need to.
Got my kit the other day. Cost a hair over $300. I've already had the main harness replaced so just going to sell that to recoup some cost.
Also, I see part # 84626011 is listed on the bag that has the sensor splash guards. Seems to be only a $20-30 part. Fort the guys that want to just buy the covers you could probably pick them up.
I installed my repair kit yesterday. I'm still getting the popup on start saying to service the system, but once I clear it, it no longer comes back while driving, which I suppose is good. I plan on taking into the dealer sometime next week to program the sensors but I hope things are not still messed up. I kind of hoped the error at least went away.
The error always goes away once you clear it and doesn't come back when driving - at least ours has always done that.
Been following this thread for a bit. Wasn't really sure about the loss of the display screen. Then came Saturdays rain, while I was driving Service Side Detection and Parking Assist, and my screen went out. Guess I'll have to talk to the dealer today. I know I'm over the 80k mark but under the 6yrs. You lose all function of the screen, luckily the steering wheel controls still work.
Oh really? Most interesting!
I don't think ours ever did that, except for when it was shorting out the harness and "restarting" everything.
Interestingly, the class-action case may be re-opened? www pacermonitor com/public/case/24563741/Hudson_et_al_v_General_Motors,_LLC
I am not really too concerned, as mine was already fixed (for free) and has been working fine for the last couple weeks.
