So we had a nice cold snap here, went to hit the wiper fluid and the wipers, no dice..
Thought hrm, it may be frozen, or the fluid was low.. Fluid was low, but not empty, topped off the tank, let it sit for a bit an warm up, thinking that if it was frozen that would be the case..
No dice.. with the engine warmed up, the fluid full, turned it off, set it to accessory and tested it again.. Wipers work, but NO pump noise on either position that should get a spray.
Ok, so I am thinking blown fuse, bad pump or bad switch.. Wipers work, they respond normally.. I check the fuse (based on the manual, its fuse 56 i believe). Fuse is good..
So we are now down to bad pump, or some how that part of the switch is dead.. (but looking at the part it looks like a sealed unit, so wouldn't it be odd for the other functions, wiper speed etc to work and the other one be dead?)
I would prefer not to go to the dealer, we just moved, and I my last Chev Dealer was great, AFTER we had a big issue, I had to get GM and the Service Manager involved.. I would prefer not to have to go through that again with a new dealer..
Thankfully, I am still under warranty..
