2012 Chevy Cruze LLS 1.8 lt P0011 I give up!
13K views 8 replies 4 participants last post by  Hodakaguy
What's the status of the engine oil? The system uses the engine oil pressure like a hydraulic system to make the changes. P0011 means the system isn't effective. Activating the solenoids isn't causing the timing change. It could be low oil, low oil pressure, etc.
Shorts/opens should set a different code. This code indicates the engine isn't doing what the computer wants it to do (change the timing).
