(1) Going from 1st to 2nd in my manual Eco, If I pull the gearshift even slightly toward me it hangs up in a notch on the left of neutral, and then, once I clear that, it hangs up on a ledge to the left of the entrance to 2nd gear. Both stop cold the transition to 2nd gear. I then have to slide the shift lever to the right a half inch or so before I can pull it down to 2nd. So .. To shift from 1st to 2nd and not have a lockup, I must pull the gearshift reasonably gently STRAIGHT down.
(2) Downshifting to 2nd, sometimes, is often like hitting a brick wall; it just won't go in no matter how much I wiggle it around. Example: In traffic, approaching the freeway, my speed was such that going from 3rd to 2nd was the right thing to do. The transmission would NOT go into 2nd. By then I was going too slow for 3rd gear and too fast for 1st. I slowed down, much to the chagrin of those who were piled up behind me, then pushed it into 1st gear and headed onto the freeway.
P.S. My last car was a 6 speed manual VW GTI. The car before that was a 6 speed manual Mini Cooper S. I never had an issue like this. Is this simply a Chevy quirk or is my car the exception to the rule?
