121 - 140 of 1,295 Posts
Very nice! This echos my feelings exactly.
I found mine were gapped just slightly less than .035" out of the box; the .035" gauge in my feeler gauge set was a tight fit. I think it's good practice for anyone replacing plugs to check and/or set the gap first.
I agree completely. I do not rely on the manufacturer. I like to check myself so I have a feeling of comfort.
A few tech videos from NGK:
Types of NGK plugs,
Spark Plug Types - NGK Spark Plugs - Tech Video - YouTube
Plug heat ranges (stock plugs are NGK "7" range),
Spark Plug Heat Range - NGK Spark Plugs - Tech Video - YouTube
How to install spark plugs (Ecotec 2.2, similar to Cruze),
Installing Spark Plugs - NGK Spark Plugs - Tech Video - YouTube
Spark plug gaps,
Spark Plug Gap - NGK Spark Plugs - Tech Video - YouTube
Proper torquing (NGK specifies 18-21 ft-lbs),
Proper Torque - Spark Plugs - YouTube
Corona stain,
Corona Stain - NGK Spark Plugs - Tech Video - YouTube
Thanks for posting those! Very informative! I learned a few things I definitely did not know.
Discussion starter · #125 ·
Not sure if it were posted or not, but I noticed that Autozone has a rebate on the Autolite double platinums for $2.25/plug, up to 8 plugs per person.
Autolite - Application Look-up Can check other vehicles that takes specific plugs too.
Spark Plug | 2012 Chevrolet Cruze LT 4 Cylinders C 1.4L SFI Turbo DOHC | AutoZone.com List of plugs for sale at Autozone for the Cruze. Put in zip code for local prices.
NGK Spark Plugs USA
Do NOT use platinum plugs in a turbo car. They hate, hate, hate platinum plugs.
I have read in a few forums, that some with force induction prefer copper plugs. I noticed at wallyworld tonight that Bosch had a new plug that was platinum and iridium. I forgot that was the whole reason I started searching for spark plugs tonight. It is a four pronger pain in the arse so probably not interested.
Reactions: NYCruze2012
Just a quick update for the commute home. This now completes 150 mile round trip commute of pure driving pleasure. Kind of makes me wonder that since I've had this car all of 57000+ miles now was I daft not to notice or even think about the possibility of the car being even better than it was "out of the box"? Basically I've had my car since 12/23/2011 and logged all these miles so far up to this date. What kind of a self induced "happy" fog have I placed myself in, or is it that I had my expectations placed too low? Little 1.4L motor not good enough for you son? Looking for that big block V8 power to come screaming out from under my hood? I know this really sounds like I am rambling, and maybe because its 4:18am that I truly am taking a long walk off the short pier. Anyway point being made here is that whatever the value is for these newly installed plugs at $2.59/plug doesn't even begin to help me express how happy I am now as compared to happy I was previously. Really blew my mind how much of a difference these plugs make. Smooth all the way thru the tach!
I may try this Friday on my down time. Has anyone tried the e3 plugs on the Cruze? They worked fine in the lawnmower but the 3100/3400 engines hated it.
Nooo to e3 they should only be used in lawn mowers that was there whole point in the first place.
Sent From An Antique,
My Original Droid.
It's the same plug. The ones in the car are just BKR7EIX-####(some other number here).
I don't know why the Autolites are being recommended...perhaps they fit the 2011 that used a different heat range plug. But that's at least 2 "steps" hotter than the NGK plugs.
I don't know, but I believe the 1.8L uses a different heat range, and it would be best to stick with that. In the manual, the 1.4 uses an ACD part 41-117, and the 1.8L uses a 41-120. That *may* be the 3923 referenced above, or an NGK "6". I just can't find a frigging conversion chart.
The best way to find out what's in there? Pull one of them out of your motor and see if they're an NGK plug. Let us know what you find out.
I just pulled out my plugs and its 3293. Looks like my third plug is faulty its all brown but with no oil on it and the coil pack turned brown as well on the third hole. I'll post pictures soon. I already bought a new coil pack and it seems to have a better material than the one I had on and I bought this from the dealer. Time to get new plugs.
Discussion starter · #132 ·
Bet that burnt coil/plug is your hesitation problem right there.
Just to be clear...3923 or 3293 came out of it?
3923 cross-references to a NGK BKR6E-11 (which is a heat range hotter than what we're using in the 1.4T).
Interesting... look at the info on the stock IFR7X7G plugs here:
NGK 91039 IFR7X7G Iridium Spark Plug
I don't know how seriously to take these bar graphs, but NGK is saying that the OEM plug is rated average for performance, excellent for longevity and POOR for fuel economy... ? That just doesn't sound right in these days of CAFE pressure and MPG competition. It also says this is a "Laser Iridium" plug series with iridium tip, platinum insert on the ground electrode AND a copper core... looks like all of their plugs have copper cores and only the tip material differs.
Now look at the BKR7E V-Power plug:
NGK 4644 BKR7E Nickel Spark Plug
Same performance and low fuel economy, but with poor longevity as well. Starting to sound like marketing to me... also claims to be supplied with a .036" gap, I measured mine at somewhere under .035". Maybe they supply them a few thou under to offset wear?
The BKR7EIX Iridium IX plug:
NGK 2667 BKR7EIX Iridium Spark Plug
Now they're claiming above average performance, only average fuel efficiency (better than the first two though), and below average longevity. WTF? I think this might be the work of the marketing department. By rating the OE plugs poorly I guess they think the customer may be more willing to shell out for an upgrade?
Forget it I can't find these anywhere locally. I just spent 15 minutes on the phone calling around. All I got was "You want to replace spark plugs on a brand new car? We don't have them anyway." lol. Oh well I'll wait a year or so.
Discussion starter · #135 · (Edited)
I wouldn't put too much faith in the FE/power ratings.
That said, lifespan was probably the most important consideration for the OEM plugs. "Low maintenance" and all that...
The Amazon retailer actually mistakenly sent me a set of the BKR7EIX-2667 plugs. I kinda wish I'd given them a test, but they weren't what I ordered, so I sent them back.
laser iridiums are meant to last longer compared to v power iridiums. Ive always known that. My civic came with bkr6eix stock and replaced them bkr9eix once it was turboed. I noticed the bkr7eix is about $4 cheaper than the factory ifr.
Coming from a Toyota background, NGK coppers were all I used. From my low performance daily driver celica to my high performance rock crawlers. I'll have to pick up a set and throw them in the cruze.
Straight from Amazon:
NGK BKR7E Standard Spark Plug : Amazon.com : Automotive
(toss a dvd or something else in your cart to get the order to $25 for free shipping)
Advance Auto Parts:
Buy NGK V Power Spark Plug (BKR7E) 4644 at Advance Auto Parts
Summit Racing:
http://www.summitracing.com/parts/ngk-4644
You're running out of excuses... :)
None at all...
You could have always sent them back claiming you'd recieved them in "used" condition. :)
