On the 1.4L, 25 NM, but if you are old fashion like me, prefer to use 18.5 ft-lbs. Furthermore, being old fashion, prefer to use an old fashion analog torque wrench. With these knew ones, hear a loud crack noise once that torque value is reached. Don't know if that is the wrench making that noise or that plastic cap is cracking.
Keep on making the same old comment to my wife, new is not necessarily better.
Two examples of this quickly come to mind, replacing that old super reliable double flare with this new bubble flare on brake lines. Not only half the meat with that stupid bubble flare, but if that bubble is not absolute perfect will get fluid leaks. Only advantage of the bubble is to the stock holders, only requires one operation instead of two for the double flare.
Another are these stupid quick couplers for R-134a service ports. A large neoprene disk is used and if it doesn't seat perfectly, will leak out refrigerant. Then you have to replace the entire line compared to the good old reliable Scharder Valve. Again, done for the stockholders to save a couple of seconds in attaching the hoses. But screw the consumers with this garbage.
