Where does this connector go? downstream of radiator temp sensor connector
3.9K views 1 reply 2 participants last post by  Blasirl
#1 ·
Good Morning All,
So i recently replaced my radiator cap and got a whole bunch of new problems. Now that my coolant system actually holds pressure ive had a small hose leak which i fixed, and most recently it pop-ed the temperature sensor out the side of the radiator. After 2 gallons of dexcool i finally found and fixed that problem but was left puzzled.
On the passenger side of the radiator i have the electrical connection going to the temperature sensor. There is 1 more electrical connector coming off the fan wiring harness that is down stream of the temperature sensor. It WAS just dangling there along with the temperature sensor itself when i found it and i can not seem to figure out what it plugs in to.
It is resting along the side of the lower radiator hose now. I have no more leaks but i am curious where this sensor plugs in to.
Anyone have any idea what this plugs in to and where? It is a hard area to get to so any help before i reach these ham hands down in there again would be appreciated.
Thank You,
Marcus
