181 - 200 of 383 Posts
140947 km now, still going strong, good temps
For those saying that the engine is running cold i took a pic of my engine oil cap, why? Easy. If you drive with a engine cold it will foam up.
I have done it guys, it took a lot of fidling around but i've done it, i was already used to it because i've already changed the thermostat back in the spring time. Started the engine, went on a 6 mile cruze, the coolant temp stays around the value of 80-90 C without the fan kicking on. After that i was a sitting duck for a few minutes to see if the temp will rise and it does, it goes straight up to 108 when the fan kicks but i started moving again at 106 and after a few yards the coolant started to drop again to its normal rate of 90. At 85 MPH (130 km/h) the coolant will barely pass 80-85 and at one point i even saw 79. Overall i am impressed by it. Next step will be to mod the fan to start at 97-98 and stop at 90 something, maybe i'll get lucky enough and it will be a nice project to do but i will have to talk to a friend of mine wich is auto electronist guru.
Please let us know how the fan mod goes, would love to adjust mine as well but not sure where to start. Good Luck!
Discussion starter · #184 ·
I'm having a hard time finding the 55593035 Dorman 902-2080 thermostat, seems to be discontinued. I did find this on RockAuto (VEMO V40991099 ),
example on ebay: Vemo V40991099 Thermostat and Housing - Engine Coolant Thermostat for sale online | eBay
, it appears to have a cage, anyone tried the Vemo or have another model number that does fit the 2012 Cruze?
Thanks,
Al
I bought the last one from the amazon. Check out for opel ampera thermostat, it should have the same core and open temp is at 80 c but i don't know if you will find that in usa.
We tried but we failed, there's too much programmimg, like literally he have to rewrite the whole thing so we ditched the idea. But we also found a solution, just turn on the AC if you stay sit in trafic :LOL:. Since the mod i have only seen like once 100 c when i was sitting in slow moving trafic but once on the move with speed over 10-15 mph it started to cool down back to 80-82.
made my change to lower thermostat sept 2020…running without any problem over a year 20k miles on change, 116k miles now on engine…should of changed sooner..car driving location, long island ny…thanks for info on change
Today i put the cooling to the test. Car packed with about 600kg on the rear axle (paper documents) on a windy uphill road. I have mainly drove it like a maniac constantly with 5000-6000 rpm(1st and 2nd gear), it barely reached 88 C. Truth be saying it was only 12 C outside but with the old thermostat i would have been afraid to play with the car as i was seeing 108 C very often on flat roads.
This is the second Cruze Ive done this mod on, and IMO neither car ran any different after the change. The coolant temps are what I consider "normal" now. I checked the temp on this second car with my scan tool after a good long drive, and ECT was 183*. Interior heat is reasonable now, not "burn you out of the car" hot like it was before, too.
There might be --- might be --- a very slight drop in fuel economy, but there are so many variables that I cant be sure.
IMO, these lower temps will help coolant parts last longer, so oil system parts will last longer, so engine will last longer, so car will last longer.
Reactions: snowwy66 and horaa
OK, let’s start!
I had multiple Cruze cars since 2011, unfortunately I can’t say I have/had one free of issues! Talking about the heating and cooling, I saw different & multiple issues reported by people. I did many changes to my cars during the years and I’m going to share with you a few interesting things about the thermostat, specific for 1.4L turbo (ECO). It can be similar issues for other trims, even for Diesel, but the cars I tested & modified are Cruze ECO 2011-2012.
Based on testing 4 cars, here are my observations:
First, the “input data”:
  1. The OE Thermostat on Chevy Cruze ECO (1.4L turbo) from 2011 to 2016, is with a wax thermostatic element that starts opening at 105°C (221°F).
  2. The OE Thermostat is also wired and controlled by ECM. Based on different algorithms and program codes, the thermostat can open at any temperature at any time, if the ECM requires that!
  3. The water temperature display gauge is… a joke! I monitored it for different cars and compared with data from OBD. The dial moves when the temperatures increases until… until 185°F (85°C) only! Then stays there, right before 6 o’clock, no matter how high is the real water temperature. When I tested this, I changed the coolant concentration, adding much more water into the system and let the engine run until the water started boiling. The gauge was at the same position max position, telling me “everything’s ok!
4. The expansion OE tank cap is opening only at 20PSI.
Under all these conditions, the coolant temperatures during normal driving conditions stays around 220°-230°F. I said normal driving conditions because when the engine is overheating, the ECM controls and changes everything. It may open the shutter grille to help cooling down and also it can open the thermostat at any temperatures it “wants”, based on data collection. So, not only that you drive with coolant at high temperature, but also the entire system is at high pressure, since the tank cap opens over 20 PSI. In theory, a higher engine operating temperature helps improving its performances. Well, maintaining a higher temperature for the engine and cooling system requires also better quality system parts. Coolant’s boiling point is way too high under the condition I mentioned so everything is ok until… One small crack into the system will lower the PSI and of course the boiling point of your coolant. Add adding more water into the system and you will lower it even more until the coolant will start boiling time to time, without you notice it I replaced the recovery tank a few times, and many hoses all the time! Many others did the same things on this forum.
Sick of changing parts all year along I decided to change the thermostat and go “old school”. It took me a while until I found something that works but here is what I did. I bought a new thermostat housing 55593035Dorman 902-2080 (GM) that is for Cadillac ELR 2014 Chevy Volt 2011-2014. Do not buy MotoRad, it is a different new model, it will not work! You need the one with the “cage”, see the attachment. The housing is different from the outside, but the internal thermostat is fully compatible with Cruze’s thermostat housing. Push the cage and rotate as in my picture, then take out the spring and “cage”. The thermostat will come out relatively easy. It looks the same as the other one, only the wax inside is different and starts opening at 176°F (80°C). Be careful with the 2 legs, don’t bend them so they can go straight back into the housing.
I’ll not got into details of how to take out the existing thermostat, there are good posts on this forum. Put everything back, and make sure you have enough coolant. Then, old school again, I changed the tank cover with one that is opening at 15 PSI, not 20 PSI (MOTORAD T46 )!
I did this replacement on 6 ECO-s and these cars have between 500 to 3200 miles since. No issues at all! The temperature goes usually up to ~184°F then the thermostat is fully opened so the temperature goes down around 180°F. I didn’t notice any drastic changes to MPG! I have hot air blowing inside the car as I had before the swap.
I did all the changes I mentioned because me and my friends have multiple issues with the cooling system since 2011. If you like the solution and have questions, please let me know. I don’t want to argue with anybody about why GM built the system in the way it is so don’t challenge me! :p
View attachment 254953 View attachment 254961 View attachment 254969
Do you have to use the OEM thermostat housing? I replaced my thermostat about 6 months ago with a Duralast one I believe. Do you know if the swap would work with the Duralast thermostat housing?
I have been fixing coolant leak issues lately and never realized how hot the engine runs normally. After doing some research and seeing a video on youtube talking about this fix, I’d like to try it out.
You should be alright with the stock 20 psi cap. No reason to go lower.
It's the stat that needs to go. That's a cooker on any engine.
By lowering the temp. You also lower the pressure.
What are you guys doing on the fan side though? That's still programmed to kick on at 230.
Start the A/C, or if you want to risk it wire it sperately and put a button for it but i don’t recommend it. For the fan spin it needs a tune and i’m not even sure that you can change it even then.
Deschiderea termostatului este de 217 F(103 C), la naiba cu asta, ma gandeam sa schimb termostatul din interior dar termostatul Cadillac costa aproape 100$ aici in romania. Voi încerca să cumpăr termostatul de generație mai veche de la 1.4 opel astra h/g și poate voi avea noroc cu asta. Mi-am schimbat deja termostatul pentru că avea scurgeri și când am vrut să schimb doar garnitura, urechile termostatului s-au rupt, așa că a trebuit să cumpăr unul nou. Mașina mea (după ce se încălzește) merge de la 99 C până la 108 C, dar aș dori și eu ceva mai rece și nu găsesc piese pentru Dorman în România sau în Europa. De obicei este între 103 și 108 C. Cum am aflat? Ușor, pentru Opel există un al 2-lea meniu în zona CB cluster care arată temperatura de răcire, încărcarea alternatorului și încă câteva lucruri.
LE: am găsit în sfârșit termostatul potrivit pentru chevy volt-cadillac-opel ampera;
CALORSTAT by Vernet 32$ https://www.autodoc24.ro/calorstat-by-vernet/12209136
[/CITAT]
I ordered the thermostat from calorstat by vernet that you found and I want to ask if it is a good replacement for the dorman! Thank you in advance!
Hello! I have an astra j a14net 2014 and I want to put the thermostat of 80 and I ordered behr or something and when it arrived I found that although on the outside it looks the same, the inside was not with the two pins. I returned it and ordered Calorstat Vernet which looks the same on the outside and the code is TE7246.80J and code 55593035 and I hope to find inside what I need to use in my case (the one with the pipe leading to the oil cooler) I now assume that I have on the car the detachable thermostat with the two legs for electrical contact. And one more thing, does the cap have to be changed? if the temperature drops the pressure drops and I say but I saw that if you stay idle the temperature rises and then a 15 psi cap (1.03 bar) would not be too small and give out?
