33K views 53 replies 27 participants last post by  obermd
#1 ·
I ordered a VG shark fin mark ii for my 2011 Cruze Eco. Does any one have it, and what are your thoughts on it?
#33 ·
I waited this long, I guess I can wait till the group buy starts and hope it gets to me before it's too cold to stick right. Already have a bottle of touch up, how much of the 3m tape were we painting? I've only seen side shots no above angles.
#35 ·
Unscrew the mast. With pure dawn dishwashing liquid, clean the area around the antenna base. You're removing wax from the car. Leaving the tape cover on, put the antenna over the base and then use masking tape to mark the front, left, and right edges of the antenna. Remove the antenna. Next, take the tape cover off and screw the antenna wire into the antenna base. Now very, very carefully put the antenna cover back on the roof of your car making sure it is straight and centered. Once it is, press down hard, making sure the antenna is completely pressed against the roof of your car and hold for about a minute. Remove the masking tape. In a couple of days you can wash and wax your car.
#39 · (Edited)
The VG is a cover to cover your existing base plus circuitry to give you a legit antenna signal. If you buy a random shark fin, you will eclipse $80 in undoing whatever you did if you wish to sell car or go back to stock. You unscrew the whip antenna, clean the surface of the roof around the base that's left behind, screw the bolt/wire to where the whip antenna came out of then glue the cover on. Hardest part is touch up paint on the 3m tape or equivalent used to secure the cover to the roof of the car.
In short you pay less for VG than s&h on whatever generic antenna you get to butcher the old one to get that one on. It's like adding a new set of wheels vs a new hub and axle for not even the same job.
Sent from my iFail 5s
#40 ·
These are super easy to install. Unscrew the old one, clean the surface, screw in the VG with hardware supplied and stick it on where you want it. There's enough room inside the base of the VG one to move it around so it's not touching the base of the stock one. The tape that's on it is super sticky and I have my doubts that it'll come off unless you hit it hard.
#47 ·
The only part of the warranty it might void is if you're having radio reception issues. The VG shark fin has an internal antenna that screws into the antenna base on your car. I kept my mask just in case I have any issues, but so far the shark fin has just as good reception as the mast.
#48 ·
I think I am going to have to pull the trigger and get me one. A nice minor change. Stupid question but would it have any affect on XM radio or just regular radio?
#54 ·
Go purchase a bottle of touch up paint for your Cruze. The color on this bottle is the color you need to request your shark fin be painted.
#53 ·
Well............I did it. I placed my order today. Seems like a nice, quick mod to keep me going. Now I just have to wait...and wait....
