Every single time I have started my car today, the cooling fan has kicked on immediately. Even when the gauge reads 3 little tick marks above cold. Any ideas? It's never done that to me before. 2011 Cruze 1LT 50,477mi
Hard to photograph, but this is what the 2 fan setup looks like.Only one fan on US gas models. Don't know about the diesel.
Given the way the ECM outputs the fan signal, that makes sense. I'll bet one fan is "low", the other is "medium", both are "high". Because that's the way the ECM outputs the fan signal. Just two relays to run two fans.
My Saab 900 was the same setup.Not sure on the Cruze, but on my previous Commodore, one fan ran when the a/c was on and both turned on when the set temperature was reached, even if the a/c was off.
Did you ever get this figured out? If so, how much was the repair? The exact same problem started occurring with me yesterday... I am not sure how costly this is going to be...Every single time I have started my car today, the cooling fan has kicked on immediately. Even when the gauge reads 3 little tick marks above cold. Any ideas? It's never done that to me before. 2011 Cruze 1LT 50,477mi
That happens on my 2012 Cruze diesel if the engine is doing a regen when I turn it off, but it turns off after a couple of minutes. As there are 2 fans it really roars for that couple of minutes.My fan just started running high speed today and won't kick down. No CEL. What is the issue? Any idea
What do you mean by "won't kick down"? The Cruze is supposed to have a 3-speed fan, but when the resistor pack dies, it transforms from low-medium-high to off-off-high. The resistor pack is not sold separately, so the fix is to replace fan assembly.My fan just started running high speed today and won't kick down. No CEL. What is the issue? Any idea
Check thermostat it was mine that cause the fan to runEvery single time I have started my car today, the cooling fan has kicked on immediately. Even when the gauge reads 3 little tick marks above cold. Any ideas? It's never done that to me before. 2011 Cruze 1LT 50,477mi
Could be air in the system or maybe the second temp sensor is bad.so have anyone found the answer to the problem
