61 - 61 of 61 Posts
I just performed this procedure and it was fairly easy to do, and took about 20minutes. Great write-up—has all the info you need. *I will mention that my updated oil line part did not have two rubber seals on the one end (even though there was a place for two), but everything else was updated, the flange, and heatshield is included—will see how long I can get this turbo to last as it is reaching the end of its life-cycle. The old feed line was leaking for sure, and after inspection one could see that the gasket has failed.
• Engine has 45k (replaced before I purchased, and with new clutch), car itself has 147k.
I just received my oil feed line in the mail. I ordered part #55592600 and received revised part #25200947 dated 2/24/23. It too has one oring on the block side of the tube. Any updates on how this part is working out for you.
61 - 61 of 61 Posts
