61 - 80 of 105 Posts
What I have heard is that the sonic have a press fitted knobs and the cruze has a screw off. Twist it to the left and it should come off. Remember they are pretty screwed in tight so apply a little bit of force.
Well I'm 100% sure my 2012 ECO is a press fit and now every time I shift it spins pissed. Now I get to call Chevy and see what I have to replace to quit the spinning.
Sent From An Antique,
My Original Droid.
Discussion starter · #64 ·
My Original Droid.
Can you pull it off? If it spins, it should come off. If it's the knob, you can just epoxy it back on without ever knowing the difference. There is a way to get my knobs to fit however, and it's quite easy but you need to get yours off first.
What's the build date on your Cruze?
Its a latter 2011 build. Nov 2011
My Original Droid.
Mine won't come off either. I tried again twisting it today and unless I put everything I have into it she won't come off... I don't want to break it so it free spins nor do I want to epoxy it lol.
I haven't had a chance to give this a spin (yuk yuk) yet, but I'll try to today. Would be ultra silly if you had to remove the boot to get the shifter knob off though, not sure what kind of apparatus would hold it on if that is the case.
Discussion starter · #70 ·
Sounds to me like GM changed them from twist to press fit some time around Nov. 2012.
The problem isn't getting this new knob to fit; but rather getting the old knob off. I already have a design for a knob specifically for people who have the press fit shaft. Devin was able to get his off. Here's what the shaft looks like.
Basically, if you can break it loose, you can pull it off. From that point, I can either design a new knob or you can thread the shaft with a M10x1.25 die and screw on a different knob. The shaft in that picture is 11.8mm in diameter so it should thread decently enough. Worst case, you epoxy the old one back on.
Not entirely sure which route to take yet.
Hi h3LLon3arth
Remember that you can send me a private message if you need my assistance. Let me know how I can help.
Jackie
Chevrolet Customer Care
This is an issue I can fix with an awesome shifter knob.
My Original Droid.
Awesome! Just reminding you that I'm here if you have any specific questions about the shift knob or other vehicle parts and features! I hope you find an awesome shift knob and are able to replace it!
Jackie
Jackie
Thanks and if I need anything ill let you know.
My Original Droid.
Hey Xtreme any luck on the shift knobs? mines is starting to peel lol and I'm looking for a replacement shift knob . Mines is a twist off by the way.
Hes still at a stand still until we can figure out a easy way to:
1. find a easy way to remove the press fit knobs
2. Figure out a easy way to modify the knob or shifter to have it work.
He has to purchase a minimum of 50 knobs per batch and this will only be a direct swap for cruzes built prior to Nov. 11'
there prob wont be enough people to buy all 50.
Plus Sonic owners are press fit as well.
Yeah that's true =\. Crap this is what I get for buying a first year car lol.
I think you mean Nov. 2011, MY2012.
My car is a late MY'12 build, I think it was built in May 2012, and it has the screw on knob. I ordered the car right before the cutoff date for '12 MY orders. Based on that I would think this change was maybe implemented for '13 MY builds (unless someone has shown otherwise?). That, or they contracted the part out to a new supplier and they implemented over time, with several functional build trials before 100% implementation.
XR, maybe you'll need two different threads inside the knobs depending on which type of shifter. For earlier builds with the threaded knob you already have a design that works, but for later builds with the press-on knob maybe a larger thread diameter is necessary, one where the minor thread diameter just clears the knurling on the shaft so that the owner can epoxy it in place. Another thing to try might be LocTite thread lock, and to remove the knob you just need to heat it up before twisting it off.
With a little creativity (and since the knob is billet aluminum) you may get away with one thread for both applications just boring the knob to a slightly larger diameter than the "ideal" spec for the thread, and then threading it. The thread's pitch diameter and major diameter would be the same but the minor diameter would increase. I don't know if this would work or not, you'd have to measure the diameter of the press-fit shaft knurling and then look up the diameter specs for the (M10x1.25?) thread.
Another thing to consider is whether the thread inside the threaded knobs is tapered or straight. I have a feeling it's tapered and this is how the knob gets tight as you screw it on. Mounting a billet aluminum knob with a straight cut thread may require the use of LocTite to secure it in its final orientation if there is to be engraving on it and you can't bottom it out to tighten it.
It may be neccesary to index the threads relative to any engraving done to ensure the knob sits properly on the shaft relative to the reverse lockout collar (not an issue without engraving). I know if I tighten mine down an extra turn so it's really tight the knob sits too low and the collar won't lift enough to get it into reverse. I would imagine the threads on the shifter are indexed for this reason but you would have to look at several cars and compare where the threads start to be sure, they may not be depending on the mfg process.
Anodizing is a great idea as it will toughen the surface and make it more wear resistant. A project I worked on a while ago had some prototype parts "hard" anodized and the resulting finish was kinda cool, a matte grey kind-of and apparently very durable from a wear standpoint. Be careful specifying funcional or Engineering processes for a cosmetic application, though, as often the process will vary with little attention paid to cosmetics.
Anodizing can be very wear resistant, but it is a very thin coating and will not resist deep scratches or denting much more than the base material. Choosing a base material with higher hardness and scratch resistance will make a more durable product, with or without anodizing. Soma aluminums take to anodizing better than others, your shop connections would be able to advise you on this with advice from their anodizing place.
Just tossing some random thoughts your way. Cool project, sorry I didn't see the thread sooner...
