2011-2016 Cruze Limited 1.4L PCV System Explained
5 reading
485K views 269 replies 72 participants last post by  Keep’n It Runnin’
#1 · (Edited by Moderator)
Video:
I made a video to help better explain how this whole PCV system works to supplement this article.
Overview:
The purpose of this post is to explain the function of the PCV system in the 1.4L Turbo engine so those of you who are having issues or trying to help people have some idea of what is going on and where to look for potential trouble spots. We will start by assuming you know what a PCV system is designed to do. If not, stop here and go to google. Return when you understand the basics of what A PCV system does. Basic mechanical knowledge is required. I will attempt to explain this by walking you through the path of the PCV system. Below is an outline of the whole system and the direction the PCV gas flows, and each step will include any pictures I could find that show the actual component described. The terms "non-return valve" and "check valve" are used interchangeably. A check valve allows a gas or liquid to move in one direction but not another.
1 We start with the crankcase that has built up pressure, under a normal operating vehicle. We exit the crank case through the cylinder head at the two long ports at the bottom of the following image.
2. Those two ports feed into the valve cover, at the two long ports on the right side of the image below.
3. From there, we travel through a baffled oil separator system. THIS IS WHY WE DO NOT NEED A CATCH CAN. This pathway inside the valve cover is tasked with separating oil vapor from the PCV gas traveling through it. From there, we exit into the small port on the left (refer to arrow at the left of image above), to go back into the cylinder head. Notice the corresponding port on the cylinder head (arrow at the top of the image)?
4. Next, we find ourselves in the intake manifold, which is pictured below. Inside this port, there is a check valve (which GM refers to as a non-return valve), pictured in the next two images. Note, this is not a ball (as it has been previously referred to). It is a non-return/ check valve, that more closely resembles a specifically shaped nipple.
5. A corrugated hose comes out of the intake manifold, which has an open path from the PCV system and does not have to go through the non-return valve.
6. We arrive at the top of the below image, where there is ANOTHER CHECK VALVE.
7. Lastly, we exit to the turbo housing at the turbo's inlet (see oil streak above).
In case you missed it:
The crankcase is under vacuum whenever the engine intake is under vacuum; the check valve valve in the intake manifold opens and pulls all crankcase gases while keeping the check valve at the turbo inlet closed. When the engine produces boost in the intake (during acceleration or uphill driving), that check valve closes due to the air pressure inside the intake manifold, because we don't want to pressurize the PCV system. When this happens, the extra crankcase pressure is relieved through the check valve at the turbo inlet. PCV gas at the intake manifold check valve flows into the intake manifold but not back into the PCV system, and air at the turbo inlet housing flows into the turbo inlet, but not back into the PCV system. Both check valves allow PCV gas back into the intake; one before the turbo and one after the turbo. I want to make sure this is clear.
When things go wrong:
What happens if the check valve in the intake manifold fails (Step 4)?
  • Excess vacuum is produced on the PCV system internals when intake is under vacuum, which may pull more PCV gas than the oil separator is capable of filtering. Excessive intake vacuum may be applied on the crank case, which may also cause premature failure of the regulator diaphragm.
  • Boost is leaked from the intake manifold into the PCV system. You may not notice this happening until more symptoms show up. The boost leak seems to overwhelm the flow capacity of the check valve at the turbo inlet, and causes positive crankcase pressure. This positive crankcase pressure then causes the turbo to leak oil internally, the CPASV seals to leak, the oil pan gasket to leak, and oil to trip from the throttle body at the connection to the intake tube.
  • Excess positive crankcase pressure caused by the boost leak will cause the burst disk in the valve cover to rupture. Since the check valve itself may not show any other symptoms of failure, you may find yourself constantly replacing intake manifolds until you address the root cause.
  • In the event that the turbo inlet check valve is stuck in addition to the intake manifold check valve disappearing, oil consumption will increase. See below under "if you are burning oil."
Notes: The intake manifold check valve can either disappear completely due to fatigue (it's rubber after all) and be ingested by the engine through the intake, or it can be stuck open. To inspect this check valve, pull the corrugated hose off of the intake manifold, and shine a light in there. If you see nothing, dip a cotton swab in rubbing alcohol and clean the side facing the vehicle's firewall as far down as you can since it may just be dirty. If there is still nothing there, your check valve is gone. IMPORTANT: failure of the check valve does not automatically result in elevated oil consumption.
What happens when the check valve at the turbo inlet fails (Step 6)?
  • In the event that the check valve at the turbo inlet is stuck closed, the burst disk can fail.
  • Excess pressure will build in the crank case, which will prevent the turbo bearing housing from draining oil, and will seep oil past the turbo seals to be burned in the exhaust or through the intake. (Walker Morgan noted this one). In the event that this occurs, oil consumption will increase.
Notes: If you are burning oil, remove the corrugated line and blow into it. If it does not blow freely, your check valve is stuck closed. Wipe the oil from your mouth, and replace it. A second possibility is an intake manifold gasket failure around the PCV ports in the first picture above.
What happens when the PCV regulator diaphragm (Step 8) fails?
  • Excess vacuum or boost produced on the PCV system by the intake manifold check valve (whether or not it is good) being open will cause unmetered air to flow through the vent on the cap and may trigger a check engine light. Refer to "related service codes" at the end of this article. You will hear a hissing sound in the engine bay.
  • If the either of the above check valves have failed, you may find oil vapor sprayed in the proximity of the cap vent.
Notes: The PCV regulator diaphragm may fail from fatigue, or it may fail in the event that either of the PCV check valves fail and cause excess vacuum or excess PCV pressure. A failed PCV regulator diaphragm may or may not be a symptom of another root cause.
What happens when the corrugated hose fails?
- The corrugated hose may crack and develop a vacuum leak. If this happens, unmetered air will enter the the intake under vacuum when the intake manifold check valve is open. If severe, this may trigger a check engine light. Refer to "related service codes" at the end of this article.
What to do if these components have failed:
http://www.cruzetalk.com/forum/129-...e-transmission-tutorials/49665-how-replace-valve-camshaft-cover-1-4l-turbo.html
No tutorial currently exists for replacement of the intake manifold, the corrugated hose, or the turbo inlet check valve. Any volunteers?
- I've presented a retrofit solution for the intake manifold check valve failure in the following thread that will cost 1/2 to 1/3 that of a new intake manifold while lasting much longer:
http://www.cruzetalk.com/forum/34-g...urbo/189402-2011-2016-cruze-1-4l-turbo-intake-manifold-pcv-check-valve-fix.html
Related Service Codes:
P0106 P0171 P0299 P0507 P1101 P2096
#55 ·
Update on this solution, I thought all I needed was a sealing washer, and turns out no hardware store near me has the sealing washer I need in the right size (1/2" inner diameter). I ordered two options (a bonded sealing washer, and a pair of metal/nitrile rubber washers) to see which will work best in this situation from Grainger, and they should arrive on Wednesday.
#56 ·
The stock system uses 2 paths for flow. 1 -though the orange check valve-in the intake, between crankcase vent and intake chamber-under vacuum, 2 -though the large corrugated hose to the turbo inlet, under suction when boosting. You can just put a check valve in the vac line between the intake pcv chamber, and intake to replace the orange check. g
#57 ·
There are a few problems with this idea.
1. The vacuum line you are talking about is the corrugated hose that goes from the intake manifold to the turbo inlet. That is the ONLY other place to tap into for PCV pressure. It is not easy, pretty, or guaranteed leak-proof to tap into a corrugated plastic hose.
2. Where on the intake are you going to fit the return line into securely that can withstand at least 30psi of pressure without allowing any leaks? You have no choice but to use the throttle body spacer I pictured in my post on the last page.
#59 ·
There is nowhere else to T-off a connection. The only external line in the whole PCV system is the that corrugated hose.
What vac line do you see between the intake pcv chamber and the intake itself?
Sent from my BlackBerry PRIV using Tapatalk
#63 ·
Does anyone know how long the burst disc on a new valve cover would last if the orange popper valve in the intake is gone? Both have crapped out but i need to replace the valve cover anyway as there is no improved fix. Just don't want to drop $65 to then have to buy another in 2 months. Once the parts listing is published for these parts i will be doing this mod instead of replacing the absurdly expensive manifold for that stupid little valve.
#71 · (Edited)
Cruze 1.4L (Gen1) PCV System Explained
I saw a writeup involving LOTS of jb weld to stop up the pcv valve in the intake, but also some modification of the boost pressure valve. Lots of hoses. Our issue seems to be a bit more simple to solve.
They also used a Subaru pcv valve (because turbo) and tapped a large fitting right into the manifold for pcv return with lots of work to seal it up.
#76 ·
Got the final parts in the mail to install this kit, then promptly realized I need a 9/16" drill bit to install it, so that will have to wait till tomorrow. In any case, here's the plan. Drill that hole in the bottom of the intake manifold.
Then, starting from the outside, you'll have the 1/4 adapter (male to female), a thin stainless washer, the manifold itself, the sealing washer, another thin stainless washer, and the 1/4 NTP nut.
The beauty of it is that the nut just barely fits in the port and actually rubs a little, but this means that once you get it tight enough, it will never loosen or back out, and since the barbed hose elbow is screwed into the adapter above and connected with a hose, that won't back out either.
The only thing I need to decide is if I want to use those nice metal sealing washers or a nitrile rubber washer (I bought both to experiment with).
#77 ·
#79 · (Edited by Moderator)
I'm posting this for people who need to get a solution up and running and can't wait for field testing of this kit. Proceed at your own risk.
1/4 NPT locknut
https://www.amazon.com/gp/product/B004ZLBMES/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Sealing Washer (pick one or the other)
https://www.grainger.com/product/GRAINGER-APPROVED- -4PAH7
Stainless Steel Washers (you need two)
https://www.grainger.com/product/GRAINGER-APPROVED- -2DNP6
1/4 NPT adapter
https://www.amazon.com/dp/B000BOAY4C/ref=twister_B0070TVKBM?_encoding=UTF8&psc=1
1/4 NPT elbow to 1/4 barb
https://www.amazon.com/dp/B003CEN8CS/ref=twister_B0070TV6ES?_encoding=UTF8&psc=1
1/4" ID oil Hose
Barb to 1/4 NPT $3.22
https://www.amazon.com/Anderson-Met...7XQ/ref=sr_1_1?s=industrial&ie=UTF8&qid=1484075073&sr=1-1&keywords=npt+1/4+barb
Bonomi Check Valve
https://www.grainger.com/product/BONOMI-1-4-VALVE-45RF27
Nipple
https://www.grainger.com/product/PARKER-Brass-Hex-Nipple-13Y796
1/4 ntp to 1/8 ntp reducer
https://www.amazon.com/Anderson-Met...070TVVSE/ref=sr_1_10?ie=UTF8&qid=1484057817&sr=8-10&keywords=1/8+npt+1/4+npt+90
BNR Throttle Body Spacer
http://store.badnewsracing.net/product.asp?itemid=580&Affid=31
The above includes everything you need for this solution with the exception of the screw and washer you'll need to plug up the check valve port. You'll have to figure that out yourself.
You will need to file two opposing edges of the flat washer that will be used inside the port as it's just a hair too wide (by maybe 1/16"). I couldn't find a thinner washer that would fit a 1/2" ID.
If you found this research to be useful (many hours went into figuring this out), and want to donate, my paypal address is Andrei@TitanSynthetics.com.
#81 ·
I haven't done the calculations from psi to bar, but the new check valve opens at 1/2 PSI, so anything under that will have gas routing through the check valve at the turbo inlet assuming that is designed to open at less than 1/2 psi.
Otherwise, the schematic is accurate.
#83 ·
Why does the orange disc in the intake face the pvc chamber-it only opens under vac, closes the rest of time. It falls into the chamber on the bottom of intake. That chamber is connected to the intake vac -though the Solenoid valve on the bottom of intake. The line to the turbo inlet is always open to the check valve in the turbo inlet. THERE ARE @_PATHS FOR PCV GAS.
I guess we will have to agree to disagree. If you just finally looked at the vac nipple , you have not studied the system very well. I believe your system will work . But it still requires removal of the intake which about 1/2 the people wont be willing to do. G
#84 ·
The context of your initial reply was read with regard to the solution I presented for people. Otherwise, you're only stating the obvious; what I already explained in the initial post. There are two paths for PCV gas, but there is only one physical line you can tap into if you wanted to install a "T" fitting.
I've known about this vac nipple and have studied this system since I first heard of the first failure. I diagnosed it myself and brought it to GM over a year ago for repair, and have in fact studied the system very well.
Any solution presented for this intake will require the removal of the intake. The members here who don't want to take the time to remove their intake will instead have to pony up the $350 in parts and who knows how much in labor for their dealer to do it. $140 vs $500? I'd learn how to unscrew a few bolts for that. This solution is not intended for the average owner; it's intended for the enthusiast that owns a few tools and comes here looking for a cheaper solution to spending $350 on another manifold that is guaranteed to fail.
#87 ·
Great ChevyGuy, I almost started to draw the PCV valve that is part of the valve cover, but then realized I have no idea how it works. I thought it was the P in PCV too, then I started to sway towards it is a burst disc. Looks like you're saying it would act like a check valve, so if under the valve cover is under positive (+) pressure the check valve stays closed, so when the valve cover is vacuum, it draws in outside air.
I hope that thing has a screen or filter in it, sucking air while engine braking on a dusty road doesn't sound exciting.
