speedometer spiking up to 120 while stopped?
55K views 85 replies 46 participants last post by  ChevyGuy
#1 · (Edited)
:question: anyone heard of anything like this before I've noticed it probally 4 or 5 times for sure but other times I questioned it. Speedometer spikes both digital and needle when stopped at a stoplight or rolling slowly usually shoots between 80-120. I have a 2011 cruze 6spd mt bought back in march with 11k miles now. No problems till I noticed this recently anyone know a problem / solution or should this be checked by dealer ?
Edit: it only happens seldomly not all the time maybe 2 or 3 times a week ( that I notice )
#2 ·
...it's a known problem. Take it back to the dealership for correction.
#4 ·
Is there a tsb or anything ? Took my car in for the steering shaft recall which they previous told me it wasn't under recall about 3 months ago got a postcard saying I needed to get it checked. When I did get it checked for recall I told them about the speedometer he looked at me said that's weird and told me it'd take 10 mins to look at the recall and sent me on my way I'm really disapointed with Chevy service departments right now . Once again they blew off another concern of mine
#5 ·
I had mine in for the same problem. Dealer really couldn't find what the problem was. The contacted TAC and they had no files related. The were instructed to recalibrate the body control module and they swapped the ignition main relay. I have had it do it again once or twice and only briefly so it is not that bad. If it gets worse I will mention it again.
#8 ·
...check: PI-0276A - Chaffed Wheel Speed Sensor Harness.
Reactions: bbdhomer
#10 ·
Same or different?
I do not have this problem when driving/stopped but both my tach and speedometer go all the way up as soon as the car starts, while all of the warning indicator lights are on. Only lasts a second and NO, my foot is not on the gas. The car does not rev, only the needles move. Is this normal?:question:
#45 ·
Spiking when starting is normal and is not a problem. The car is doing a self test(like the dash lights coming on then going out when started). Since everything is electronic including(tach and spedo) they run thru a series of tests. Spiking when at a light is not normal. Happened to me one maybe 2 times but not regularly. So I don't worry about it. Problem with VSS?
#11 ·
...that "initial" 'full-scale sweep' is normal operation.
#19 ·
I've been having the same issue with my '11 Cruze. It's happened just under a dozen times since I purchased the car in Feb of this year. All my guages max out, the interior lights come on and my stereo blasts up to full volume. All lasts about 1-2 seconds and only when my clutch is engaged.
Scares the s**t out of me everytime with the sudden volume increase, lol.
Thinking it's time to take it back to the dealer. My question is... how many other people are having this issue and does anyone know for SURE if GM is aware of this? Just want to have some info in case I receive any push-back from the service department.
#21 ·
I bought my Cruze in March, I've had this problem since day one... They've replaced the instrument cluster and vehicle speed sensor, still having the same problem. The dealership managed to replicate the problem, so they know there is a problem but want me to continue driving it. I've refused... they have the car and I'm currently driving a rental car, going on 2 weeks... I've been in contact with GM Canada the whole time, this is ridiculous that I'm having electrical problems on a new car!! It's obviously a problem with manual transmissions... Any other suggestions??
#22 ·
Am I correct in that this problem is limited to '11 Cruzen only?
Jim
#24 ·
I think your a a little late FatKidsCruze. Yes it is normal for the gauges to do a full sweep on initial start up, but it is not normal for the speedo to spike when the car is rolling or inching at a stop. This also causes the radio to jump in volume as well. Mine has done it a few times and the dealer looked at it with no result. At least it is on record and judging by the number of other complaints, hopefully they will find a solution.
#31 ·
well im just trying to get over the antifreeze smell in my car and here we go with a new problem. I parked my car and when i pulled the e brake up warning chimes started dinging like crazy and the display said release emergency brake!!! I happened to look at the speedometer and it was at 25 mph and dropping. I have come to expect a new issue every 1-2 weeks now.
#35 ·
cruzeman,
I would like to apologize for the issues that you have experienced with your Cruze. I would suggest that you take your vehicle back into your dealership and have them look into this for you. I understand that this is frustrating for you. Please keep me updated on the outcome of your visit to your service center. If you have any additional questions please feel free to message me.
Thank you,
#32 ·
...to quote the old Crackerjack™ jingle: "...a SURPRISE in every package..."
Reactions: izzyizz
