501 - 520 of 932 Posts
Discussion starter · #501 ·
I'm scared to do this kind of work to my car, I've only ever messed with stereo/wiring before! But I'm sick and effing tired of the drop of MPG that happened three years ago, that and a few other things that all seem to match the symptoms of the pvc valve being the issue on my 2012 Eco.
It's really not that bad of a job. The worst part is getting the intake manifold off and I have a tutorial for that.
Read both the intake manifold and pcv fix kit install tutorials and they'll give you a good idea as for what to expect and what tools you'll need.
Sent from my BlackBerry Key2 using Tapatalk
So took my hose off to check how the fix looked, it seems some of the epoxy has maybe let lose? I am a bit worried about it, it didn't look like this upon reassembly. It was cleaned thoroughly with brake cleaner. I poked at the main glob of epoxy with a screwdriver and it seems solid, but these look like bits that have come off? Think it's worth taking everything back apart, cleaning and putting more epoxy on? I remember it stumbled when I first started it, wonder if everything wasn't dry enough?
Discussion starter · #503 ·
View attachment 270209 View attachment 270211 View attachment 270213
I usually recommend scrubbing with a brush. I'm guessing there was some oil deposits still stuck there that caused issues with sealing on some parts.
Should be fine around the screw though. I've checked mine a few times and it was good each time. In the video I'm making for this, I'll be specifically recommending scrubbing it really well with an old toothbrush or something. That should be sticking pretty well.
The most important part is the washer, screw, and the holes the two are covering. As long as those don't budge, you're good.
Thanks for the reply, any risk of that stuff getting sucked into the hose? Maybe I worry too much...
Discussion starter · #505 ·
It's not high air volume or high flow rate around there. Not a whole lot to be worried about. Just make sure you clean it out if you do scrape some off.
Discussion starter · #506 ·
I went in and checked mine. I've had it for longer than anyone else. It's all still solid. The thin areas flaked up a bit when I scraped at it but didn't break off. The screw is still in there solid. Note I used a hex head screw on mine so it looks a bit different. Thing wouldn't budge when I pushed down on it. I have some moisture there from the short winter trips but otherwise it looks fine.
Discussion starter · #507 ·
I just went back with a better flashlight and a longer screwdriver. The thin areas I didn't clean too well got a bit flaky once I scraped it off but it's all still solid. The thin areas have a "rubbery" texture but the thick areas are like soft plastic. Still solid. Its been there since January 2017 and it's still doing its job. I just boost leak tested it a couple months ago and it didn't leak. So far so good. I'll make sure to note in the video tutorial that you need to scrub the area well with as toothbrush or it won't adhere properly, and to just put a big dab of the stuff on the screw and not worry about coating all around it. That doesn't seem to have done any good.
Nice, I have a rough understanding of the PCV system as I've reviewed the thread for it and watched the video, didn't realize this would show up in a boost leak test though. I am all good if that's the case as I did one a couple of weeks ago, head a leak, but at the throttle body clamp, after retest was good.
Discussion starter · #509 ·
The boost will leak into the crankcase through the piston rings and pressurize that if you leave it long enough so you'll notice some leak early on but it will take a while. I had one friend that heard a leak when he was boost leak testing and couldn't figure out where; turns out the OEM check valve in the intake manifold had somehow become stuck open so it was leaking boost. He pulled the corrugated hose off, sprayed it with soapy water, and sure enough it started bubbling at that spot.
Joined this forum and ordered the V2 today along with a boost/coolant leak check kit and a new valve cover from amazon. Can't believe this PVC system isn't the subject of a recall or extended warranty program.
Hi All (2013 Cruze 1.4 w turbo), so i replaced the valve cover (OEM) then added the V2 fix kit to the intake and as i was wrapping the job up and congratulating myself on a good job.
I noticed a small black hose w green stripe hanging in the back of the intake manifold with a plastic nipple broke off inside. The other black hose with green stripe was in place attached to a component (not sure what it is) and that hose is fed by a small hose from the turbo and hooked up properly.
After extensive looking with a mirror and flash lights, i cannot figure out what this hose is supposed to be plugged into? To fix it. I've got the line plugged but thats just temporary.
NOTE: the engine runs great w lots better gas mileage.
Im getting codes:
PO 171 once (sys to lean)
PO 496 3 times (Evaporative emissions system high purge flow)
PO 15B (02 sensor delayed response)
Question: so before i go trusting the codes, i must repair / replace this hose/nipple and recheck the codes after its done.
Last weekend I completed Andrei's PCV V1 fix on my 2012 Chevy Cruze RS. Install went well. The only thing that went wrong was when re-installing my fuel rail and connecting the sensors to the injectors, one of the injectors popped out. I pushed back in and have noticed zero leaks this past week. No CEL and the car is running great. The reason for this post is to inquire to see if after this mod, has anyone noticed a humming noise coming from the engine bay? I believe it's coming from the intake manifold/throttle body? Does not squeak when turning to one side, so I do not suspect wheel bearing. This noise is not existent during idle. No exhaust, tuned back to stock, K&N intake.
My daughter (2012 Silver 1LT) got the dreaded P0171 and her PCV system crapped out on a road trip from Norfolk, VA to Oklahoma City via Phoenix. The service department at Jim Keras Chevrolet in Memphis had the parts and are working to get her back on the road quickly. Kudos.
I shoulda done this mod for her this last month. I won't see the car again for two years.
I bought that Dorman part for my Cruze (2012 Eco) a couple of years ago. I wonder if it has that retainer clip.
I still have my old original manifold sitting in the garage. I'll have to buy a couple of XR kits and retrofit my daughter's car and then mine the next time I see it.
