921 - 932 of 932 Posts
Greetings. Don't recall how I stumbled on to this forum, but the PCV discussion is interesting. Lots of detailed information. Thanks XR. And others. Anyway, I recently bought a '15 Encore w/62k. No symptoms indicating any bad valves, save for a couple of weeks ago after the car sat for about 10 days I had a rough idle a couple of times but nothing since. But it would seem prudent to be proactive and install the 3.4 kit anyway. The orange nipple is visible but I did read where that's not necessarily a good indicator that it's working correctly. I think i also read where it's possible to push the check valve out with a pick or stiff wire. Anyone done that? And does it make sense to go ahead a swap out the cam cover? Or if it's not broke, don't fix it?
Welcome Aboard!(y)
Don't forget to introduce yourself and your Cruze here: https://www.cruzetalk.com/forums/👋-cruzetalk-new-member-introductions.6/
As long as the engine in question is an LUJ/LUV you can install this fix. There is no need to remove the intake manifold. If the cam cover is not leaking and the PCV vacuum regulator is not ruptured you do not need to replace it either.
Discussion starter · #922 ·
Yes your understanding on these topics is correct. You can either wait for the check valve to fail or you can cause it to fail yourself and then install the kit as preventive maintenance. The cam cover can be left alone until it fails as that could potentially last another 50,000 miles.
I bought one of your kids that replaces the corrugated hose to the turbo inlet but that hose goes into a check valve and then splits into various rubber lines that connect onto the top of the Intake manifold. Did the repair with the epoxy but there is no hose that runs under the intake manifold through some drilling of the intake manifold? Did I buy an old obsolete version of your kit?
Discussion starter · #924 ·
The V3.4 is the newest kit and does not go underneath the intake manifold. Drilling was required with the V1 and V2.1 kits.
Welcome Aboard!(y)
Still running the original version of the V1 or V2.1 PCV Kit. I have cleaned the check valve a couple of times and transferred it to two different intake manifolds but it is still a very durable fix well over 100K miles and still clocking on motor #2 .
I have the V2.1 kit with almost 20,000 miles on it and never cleaned the check valve yet.
Reactions: Blasirl
One time a piece of carbon flaked off and got stuck in the check valve and the other time was cleaning maintenance during plastic Intake manifold swap. The original manifold was leaking at a seam.
Yea I should probably clean my check valve
I could tell when mine was not functioning, when I pulled the dipstick at idle there was no vacuum at the hole when you put your finger on the hole. I have since added a vacuum gage to help monitor vacuum at idle & turbo boost.
Yeah, I was on the Cruze Kits website yesterday and that's one of the things that they said to check was vacuum, with the oil dipstick and also oil consumption
Well yesterday, my boost gauge was showing low to no boost pressure. My gauge is downstream from pcv v2.1 kit check valve. It was time for a check valve cleaning. I was able to shoot a dose of carb cleaner down the vacuum hose at where I Tee'd in my boost gauge. I let it sit overnight and today I can see my boost pressure again. I was prepared to pull my intake to get access to clean that check valve. Thought I would share this trick with anyone with v1 or v2.1 kits.
